• Contents
  • Lychee Schedule Management
    • Gantt Chart
      • Setting Permissions
      • Changing Dates (Period)
      • Changing Dates (Start Date)
      • Setting Dates
      • Solid Lines Displayed in Gantt Charts
      • Creating a New Issue
      • Editing an Issue
      • Changing Sequence of Issues
      • Changing Parent-Child Relationships between Issues
      • Collapsing/Expanding Parent-child Issues
      • Setting Display Colors for Issue Statuses
      • Changing Version Status
      • Downloading PDFs
      • Setting Headers
      • Full screen Mode
      • Expanding and Shrinking
      • Changing Displayed columns
      • Sorting
      • Saving Queries
      • Editing an Issue by Double-clicking
      • Manual Sorting
      • Opening and Closing Entire Levels
      • Group Conditions
      • Undo Function
      • Issue Adding Mode
      • Displaying Notes on Issues
      • Displaying Higher-level Issues
      • Critical Paths
      • Saving a Baseline
      • Applying a Baseline
      • Displaying Progress Lines for Baselines
      • What is a Milestone?
      • Adding a Milestone
      • Displaying Versions with No Linked Issues
      • What is Simulation Mode?
      • Operating Simulation Mode
      • What is Visualize user workload?
      • Operating Visualize user workload
    • Kanban
      • Project Settings
      • Setting Maximum Number of Displayed Issues
      • Kanban Operations
      • Kanban By Priority
      • Kanban By Assignee
      • Burn Down Chart
      • Backlog
      • Backlog Operations
      • Points Display
    • Issue Set
      • What is Lychee Issue Set?
      • Creating a New Issue Set
      • Editing an Issue Set
      • Editing an Issue
      • Selecting an Issue Set to be Used by a Project
      • Creating an Issue from an Issue Set
      • Creating a Child Issue from an Issue Set
    • Project Template
      • What is Lychee Project Template?
      • Main Functions
      • How to use Project Template
    • Actual Date
      • What is Lychee Actual Date?
  • Lychee Resource Management
    • Time Management
      • What is Lychee Time Management?
      • Main Functions
      • Getting Started
      • My Calendar Screen
      • Selecting Projects
      • Placing Issues
      • Placing Project activities
      • Placing Project-unrelated activities
      • Changing the Display Week
      • Changing the Calendar Time Units
      • Project Calendar Screen
      • Member Search
      • Changing Displayed Members
      • Daily and Weekly Displays
    • Time Management: Google Calendar add-on
      • What is Lychee Time Management Google Calendar add-on?
      • Obtaining an API Key from Google Cloud Platform
      • Redmine Settings
      • User Settings
    • Resource Management
      • What is Lychee Resource Management?
      • Resource Management Settings
      • Project Settings
      • Resource Management Functions
      • Workload
      • Working Rate
      • Productivity
  • Lychee Basics
    • Project View
      • What is Lychee Project View?
      • Displaying Projects
      • Quick Links
      • Project View Settings
    • Version Start Date
      • What is Lychee Version Start Date?
      • Setting a Version Start Date
    • Easy Assign
      • What is Lychee Easy Assign?
      • Display of Project Members by Group
      • Filtering by Group
      • Assigning Responsibilities Using Predictive Search
    • Work Days
      • What is Lychee Work Days?
      • Settings
    • Issue Spreadsheet
      • What is Lychee Issue Spreadsheet?
      • How to edit issues from the Issue List
    • Status Color
      • What is Lychee Status Color?
      • Setting Colors
      • Displaying in Lychee Gantt Charts
      • Displaying on Lychee Kanbans (Backlogs)
    • Profile Icon
      • What is Lychee Profile Icon?
      • Setting User Icons
      • Setting Group Icons
  • Lychee Project Report
    • What is Lychee Project Report?
    • Project Settings
    • Setting Indicators
    • Creating a New Indicator
    • Displaying Indicators on the Report Screen
    • Settings for Each Project
    • Overall Project Report Screen
    • Individual Project Report Screen
    • Saving Queries
  • Lychee Cost
    • What is Lychee Cost?
    • Visualizing Project Receipts and Expenditures
    • Project Settings
    • Setting a Budget
    • Setting a Hourly Wage
    • Inputting Expenses
    • Linking with Lychee EVM
    • Linking with Lychee Project Report
  • Lychee EVM
    • What is Lychee EVM?
    • Displaying EVM
    • Calculation Method for Basic Indicators
    • Selecting Versions to be Displayed
    • Selecting Base Date, Display Unit
    • Zoom
    • Displaying Selected Charts
    • SPI+CPI Display
    • Calculation Method of SPI, CPI
    • Baseline Comparison
    • Exporting
    • Revising Progress for Past Dates
    • Displaying EVM Values on the Issue List Screen
  • Lychee Custom Field
    • What is Lychee Custom Field?
    • Category Settings
    • Settings for Linking Custom Fields (Controlling Required Items)
    • Settings for Linking Custom Fields (Controlling Selection Options)
    • Managing List Items for Different Projects
  • Issue Association Chart
    • What is Lychee Issue Association Chart?
    • Displaying an Issue Association Chart
    • Issue Association Chart Legend
    • Filtering Information Displayed in an Association Chart
    • Associating Issues
    • Deleting an Association
    • PDF Downloads
    • Fullscreen Mode
  • Lychee SAML Authentication
    • What is Lychee SAML Authentication?
    • OneLogin
    • ADFS(Active Directory Federation Services)
  • Published with GitBook
Resource Management
Resource Management
    • Project Settings
    • Workload
    • Working Rate
    • Productivity
results matching ""
    No results matching ""
